Re: Proper trailer tire inflation
Guys - I'm not trying to tell anyone to run their tires underinflated, just the opposite - tires need to be inflated sufficiently to support the load placed on them.  That's what the Goodyear chart says: "Tire load
limits (lbs) at various cold inflation pressures..."  Of course this being the USA, each individual is free to do as he sees fit.
  <br /><br />I think one of the benefits of forums such as this is the general increase in knowledge stemming from open objective discussion.  So with all due respect to the learned opinions of others and at the risk of getting flamed, let me just say that I spoke with a Goodyear dealer who confirmed that the chart gives the
minimum inflation required to support the listed load
per tire (divide total load by number of tires to get individual tire load, hence minimum inflation per tire).  So, as recognized by some of you, the total weight of the boat and trailer must be known if the tire is to be inflated to something less than max, although inflating it to the max is eminently acceptable.  For those who don't know the weight of their rigs or who have barely enough tire, certainly they should inflate to the max (and pray that's enough).  By the way, look closely at your tire sidewalls...nowhere does it say to "inflate to 50 psi".  What it says is "Max load 1760 lbs at 50 psi cold" which is not a
requirement to inflate to 50 psi, just a statement that the tire can carry max load of 1760 pounds when inflated to 50 psi.<br /><br />I agree that, as many have said, most tire failures other than physical damage from punctures, etc. are due to underinflation (psi too low for load) or overloading. I've towed for over 29 years with zero failures on tires inflated less than max but more than enough to carry the load.  My 5420# boat/trailer runs on four load range C tires inflated to 40 psi (4x1530#=6120#) with no problem.  Proper tongue weight prevents any sway and I've never had such problems, even when someone-with-less-than-full-mental-capacity cuts in front of me
  and forces a panic stop.  At least in my experience it isn't an absolute necessity to inflate tires to max psi, but it is an absolute necessity to inflate sufficiently to carry the load.<br /><br />Lots of good discussion.  Peace and Aloha.
