Re: Proper trailer tire inflation
Not meaning to start a war of words or anything, just want to point out that the Goodyear website lists load/inflation information that gives tire load limits at various inflation pressures for ST tires. See the below link:<br /><br />
ST Tire Load vs.Inflation<br /><br />This would seem to indicate that trailer tires need
not always be inflated to maximum rated, as long as the load and inflation pressure match, i.e. the tire is inflated enough to safely carry the load placed on it.<br /><br />The local trailer tire guy says to always inflate to the rated max pressure cold, but that leaves no margin for
unexpected pressure increases. Trailer tire design allows for an increase in pressure above max rated resulting from
normal tire heating, but what about
abnormal heating like when a brake drags or a bearing starts to go? Seems prudent to inflate only enough to safely carry any expected load and leave the rest as a safety/comfort margin. Besides a softer ride from tires not fully inflated, there'll be some added margin in the event of unexpected heating and pressure increase. It could be the difference between a dragging brake causing a blowout or just finding and fixing a dragging brake when you get home.<br /><br />As an example, if you're trailering 2100# on a single axle with ST175/80R13
B tires the Goodyear info shows that you'd better inflate to max 35 psi to carry that load. But if you had ST175/80R13
C tires you could still carry that 2100# load at 35 psi instead of the max 50 psi. Prob'ly be good to go to 40 psi, but you see that'd still leave 10 psi 'cushion' against any blowout from the tire overheating and pressure increasing due to a dragging brake.<br /><br />If you're max'd out on your trailer tire load rating, then inflate to max psi. If you're not maxed out on load, you don't
have to max out psi. Just my 2¢...
