Proper Standard Fuel Pump to Replace VRO?
randyhall
Can anyone help me get a part number for a standard fuel pump to replace my vro pump? It's a 1987 Evinrude XP200 E200STLCUA 200hp.
Thanks!
Haffiman
Re: Proper Standard Fuel Pump to Replace VRO?
On that engine, not recommended to use the smaller pump, but the no-oil 'vro' pump. Uou might as well plug the oil side (if defect) and rebuild air and fuel side on your old and run pre-mix.
randyhall
Ok, so you're saying there's no good fuel-only pump solution for this motor? My best options are to rebuild the existing VRO pump's fuel side, or replace the VRO pump with a new VRO pump and utilize the fuel side only?
Oh, and I should have mentioned originally that I have disabled the oil side of the current VRO and use pre-mix. That's probably a given based on my question, but thought I should clarify.
emdsapmgr
Bombardier sells a VRO type pump which has no oil side to it. Fuel only. You have to premix with it. This new pump may save you nearly $100 over the normal combination oil/fuel pump.
tx1961whaler
PN 5007422 is the "pre-mix fuel only" replacement pump
Haffiman
If your present set up is working, why change? The fuel-only 'VRO' pump is the same as your present set-up, just that the oil is removed and blocked in a different way.
randyhall
The present setup isn't working. It runs ok at idle, but not under a load, and it leaks fuel. The pump is failing/failed. So I need to either rebuild the fuel side or replace the whole thing since I use premix now anyway.
