Proper rpm's at wot for 1985 140 vro
Salty Sal
Just had a new powerhead installed on a 140 1985 <br />looper. What is the suggested rpms this engine should be running at wot. I've heard so many stories on these specs that I am thoroughly confused. Correct prop for this engine? Thanks for your reply.
Dhadley
Re: Proper rpm's at wot for 1985 140 vro
Whether its still a small bore or not, it should be capeable of 5800 to 6000 with an average load. The limiter is at either 6200 or 6700 depending on which pack you use.<br /><br />Champion plugs, fresh 87 octane and good oil. Obviously with a new powerhead you have a new water pump assembly so youre good to go there. <br /><br />Good luck!
Salty Sal
Thanks Dhadley.<br />Small bore 3.500. 87 octane.Carbs rebuilt and new waterpump.
Dhadley
Let us know how you make out. <br /><br />Good luck!
Solittle
Make sure that you go through the breakin if you haven't already before you run it WOT for very long.
