Admiral Bird
Thread starter- Joined
- Sep 14, 2013
- 3
There appears to be alot of knowledge out there on propping and I hope someone can help me.
I have a 17' lund which has now a 1997 40HP Force outboard. Total gear/people weight is normally around 500-700 pounds.
I took the boat our recently (at about 7600' altitude) and could only obtain a top GPS speed of 11 mph. At 11 mph my rpm was only 3500. The WOT RPM recommended is a min of 4750 and max of 5250.
I am using a 10.5 X 14P alum. prop which came with the motor. I have two other props (in need of repair) ;one a 15 pitch and the other a 13 pitch. Now I understand that by lowering the pitch by one number I should gain about 200-250 in RPM but I am not sure if this will give me more speed or less. I am waiting for good weather to get on the lake to find out what changes I can achieve.
Does higher RPM normally give more speed or less.
Is it possible that I have a jetting problem as well and if so how can I tell if the carb is jetted properly for that altitude?
Thanks in advance for any and all advice.
