Nightsnorkeler
Thread starter- Joined
- Jul 23, 2011
- 5
I am new to this forum and this is my first time attempting to make a repair of this type. I have a 24' Harris Flotebote, approximately 40 years old, with a 2006 Mercury 25 HP 4-stroke (F25EL). It was mounted by the shop that sold us this new motor back in 2006 and the wood has deteriorated to the point where it needs to be replaced, and I've decided to tackle this job myself. I've already read many posts and spoken to boat builders, etc. so I'm pretty confidant about the job, I'm just not sure how high I can safely mount this motor. I will be using 3 sheets of 3/4" plywood glued and sealed with resin which I've been told is good as long as it is sealed well.
As you can see from the picture, the motor is currently tilting back due to the flex of the old wood which makes it sit lower in the water. We are on a very shallow lake, so I'd like to mount this as high as possible to avoid bottoming out in the sand. Speed is not really a concern as we only use this boat for cruising on our rather small body of water. The way it sits right now, the water line was right at the level of the top of the three plates on the shaft. Would it be safe/advisable/appropriate to make the transom higher so that the motor sits higher in the water, maybe at the middle plate or somewhere between them?
Thank you very much for any advice you can give, and please forgive me for not using proper boating terms, but I'm just a weekend boater with some time on his hands and not afraid to get them dirty!
