friend want to change gear case lube, what is proper?
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Dec 5, 2005 #1 friend want to change gear case lube, what is proper?
WillyBWright Fleet Admiral Joined Dec 29, 2003 Messages 8,200 Dec 5, 2005 #2 Re: proper lube 9.9 1974 9R73B The specified lube would be HiVis available from any Johnson or Evinrude dealer. Most any marine specific gearlube will work fine except those specified for electric shift outboards.
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Dec 5, 2005 #3 Re: proper lube 9.9 1974 9R73B thanks, WBW, thats waht i thought, wanted to be sure before i gave advice.
S Solittle Fleet Admiral Joined Apr 28, 2002 Messages 7,518 Dec 5, 2005 #4 Re: proper lube 9.9 1974 9R73B Make sure that you replace the seals for the fill & drain plugs.
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Dec 6, 2005 #5 Re: proper lube 9.9 1974 9R73B thamks
