In reference with this old topic if needed, http://forums.iboats.com/forum/engi...out-drive-maybe-this-is-obvious-but-not-to-me
I have a question please!
I leaned the lower half up against a log while i retracted the shift shaft. It was slightly nose down. Now it seems like everything is reversed somehow? I'm making this judgement based on the fact that when the shift shaft is straight ahead, if I rotate the prop CCW (i.e. in the reverse direction), the shaft going to the upper half rotates with it. I assume that this means that the lower half is actually in reverse when in this condition? Is this accurate? Maybe I am overthinking it since the torque actually comes in through the driveshaft to the prop. When I spin the prop, I'm actually applying torque from the propeller to the driveshaft which is the reverse of normal operation...?
