proper jack plate usage
spacerust
i have a '18 flats boat with a 150 HP outboard. What is the proper usage for a jack plate. my other boat i had a tilt/trim and i would always trim down to take off. with this jack plate can i leave it in the same position all the time? if i am in shallow water can i run and take off the same way? i put it all the way down to take off and then trimmed up but it seems that all i need to do is just give it some go and she's fine. the bow doesn't come up like my aluminum one did.
tashasdaddy
Re: proper jack plate usage
if you boat performs like that, fine do it. every setup is a little different.
