proper amount of water pumping out
kayleedid
:confused: I am a new boat owner and I want to make sure my motor is pumping out enough water. How do you know, I had it out once and everything ran fine but there isn't very much water coming out especially when I compare to other boats. It is an Evinrude 60hp 1974. Thanks for the help
The Marine Doctor
Re: proper amount of water pumping out
I believe that the majority of the water is pumped out below the waterline.<br /><br />TMD
OBJ
Hi kaylee...could you post a model number of your engine? I don' think it's a 74' as you posted. 60hp's didn't happen from 72' to 79'. <br /><br />Does your engine have a "pee hole"? If not, there are a couple ways to check water flow.<br /><br />With the engine running and warmed up, you should be able to touch the flat spot on top of the engine right behind the head without jerking your finger off. Should be able to hold your finger there for several seconds. Your engine should run between 140 & 145 degrees at that flat spot at low rpms. I will increase some as rpms go up.<br />Look at the exhaust relief ports just below the engine pan on the back of the motor. With the engine running and warm, you should see a misty spray from these ports.<br />The water that has gone through the block mostly exits through the midsection and out the prop hub.<br />Don't forget that model number so we can find the correct year of your engine. Thanks!
