propeller shaft is hot on my trolling motor
sacalaitman
I had to take down my motorguide great white to straighten out the shaft. after i everything back together on the bottom end, I tested it without the prop to make sure everything was ok. the propeller shaft got really hot but not the housing. just the shaft. is this something i should be worried about? it is making a little noise, but nothing more than it was before i took it down. the shaft spins freely. any ideas on what might be going on, or does the water cool the shaft down?
NYBo
Re: propeller shaft is hot on my trolling motor
Welcome to iboats!:cool:
I don't think you're supposed to run a trolling motor out of the water for any great length of time. The water does indeed cool them.
Silvertip
Honorary Supreme Mariner
The shaft has the armature windings on it. Heat from those windings passes to the motor shaft. In the water, the shaft and motor housing are cooled by the water so yes -- water cools the motor and no -- it should not be allowed to run out of the water for that reason. If you bent the shaft you very likely damaged a bearing and possibly the shaft seal as well so as a minimum, replace the seal to avoid water getting inside the housing.
