helpmeboat
Thread starter- Joined
- May 25, 2011
- 1
I needed to replace the prop on my 1996 Johnson 130 outboard and am on my second prop. The first prop did not fit as the replacement manufacturor recommended a 13x19 prop. The motor really required a 14.5 x 19. Now my issue is whether this is correct or at least usable. The propellor shaft along with cotter pin exend beyond the propellor cone. It did not do this with the old prop. Also, there is around a 16th inch of difference between the bolt and the cotterpin after the bolt is tightened down. This means that the metal stamp (with the fingers) is loose. How much distance can there be between the bolt and cotterpin? Attached is a picture. The prop seems to fit nicely on the shafter and inserts into the motor fine. Any advice would be appreciated.
