Propeller recommendation
tygh
I have a 1991 Merc 9.9 outboard on a 10ft Achilles inflatable boat. I have no problems with performance with just me in the boat, but when I load a buddy and dive gear, the performance goes in the toilet.<br /><br />Would a propeller with a different pitch help??? Lower pitch? What would that do for performance when I am using the boat alone?? I am a true newbie to this :)
rickdb1boat
Re: Propeller recommendation
Yes, a propeller of lower pitch would most likely help with a big load. But, you would want to switch back to the regular prop. when it's just you. For example, if you are running a 9" X 10-1/2" pitch prop now, you may want to go with the 9-1/4" X 7" pitch prop with a heavy load. The Michigan Prop number for the latter one is 032056. This will fit your motor fine. It's $66.00 HERE. Good Luck,
tygh
Ok, to further show my ignorance, another question. The lower pitched prop will do what to the outboard rpm's? I get 8 knots out of the current prop with a full load. Will speed improve?
Hasbeen
The lower pitch prop will make the performance about the same with two as the other prop with one! Dont expect that little motor to do much more than it is!! and yes put the original prop back on when you go out buy yourself!!<br /><br />Hasbeen
rickdb1boat
For every 1 inch pitch, you gain or lose 200 RPM's, depending on whether you go up or down in pitch. Therefore, if you go from a 10" pitch prop to an 8" pitch prop, you will gain 400 RPM's and with a load on the boat, that will keep your RPM's where they need to be. But,like Hasbeen said, you can only get so much out of a small HP Motor. All you can do is try it.
