Lieutenant dan
Thread starter- Joined
- Apr 7, 2005
- 11
I fired my 1966 95 hp 6 cylinder Mercury Krakhauer up today for the fist time this spring in hopes to do some pike slaying tomorrow. When I hit the throttle in the yard to make sure she ran (with water being pumped into it) I looked back at the prop and it was bearly spinning and then the prop and the whole shaft assembly fell out onto the ground. There was a nut from the shaft coming into the housing from above that had fallen off. I put that back on, but can't figure out how you connect the prop shaft back into there. any ideas on what i need to do to fit it back in? It thanks for your time and good luck fishing!!!
