PROP
rebalseerebaldo
THE PROP ON MY 1995 JOHNSON 150 IS A SS PROP BUT I HAD SOMEONE TELL ME THAT THE PROP SHOLD GO INTO MY LOWER UNIT BUT MINE HAS A GAP BETWEEN THE TWO WITH A SMALL PEICE OF PLASTIC THAT LOOKS LIKE IT SHOULD MOVE TO CLOSE THE GAP. SHOULD I CHANGE THE SHAFT SEAL THE THE PROP BUTS AGAINST AND MAKE THE PROP GO IN THE LOWER UNIT OR IS THAT NORMAL?
Hooty
Re: PROP
The thrust washer is what determines how far the prop goes on the prop shaft. You may have the wrong thrust washer for that prop. Take it to a prop shop and let them look at it.<br /><br />c/6<br />Hooty
rickdb1boat
Re: PROP
On my 91' rude, the prop just barely butts up against the lower unit housing. Always been that way!
