prop stolen
river rat bama
well I lost my prop the bad way at storage facility.thieves stole 2 and we were parked side by side. sure could use you guys help.
1999 Baja Sidewinder 19'2 length, appx. 7 1'2 width, V8 305 carbureted 220 h.p., alpha 1 gen 2, 1.62 gear ratio, appx. 3000 lbs.wet, WOT range 4400-4800,
speed 50's, nauticus trim tabs that work great.cruising at 3000 rpm's 32 m.p.h
I have no knowledge of the prop that was on the boat,I know dumb me,it was a 3 blade stainless. Any prop recommendations would be greatly appreciated.Thanks.
"Baja-Speed Changes You"
Yellow Yota
Re: prop stolen
What gear ratio? That's about all that you're missing for the prop gurus to suggest a replacement. Might try to be a bit more specific on the RPM and speed.
trendsetter240
Re: prop stolen
Gear ratio is 1.5:1 if I'm not mistaken. 3000 RPM and 32mph means you probably had a 19p prop.
If you want excellent hole shot and mid range cruise performance then a 19p 4 blade aluminium solas amita would be a good choice. The amita is about 100 bucks here on iboats.
If you want more top end speed and don't mind spending the cash then a 19p 3 blade stiletto bay pro 2 is a good option.
A great all around prop is the 4 blade stainless solas HR Titan. Again, a 19p would be the correct pitch to start from.
Cheers.
EricJRW
Re: prop stolen
Also, I do see that "prop lock kits" are available. No personal experience, but I suspect it's similar to the locks used on car rims. Might be worth considering.
Go the the iboats store and search "prop lock" for more info.
drivehard
Re: prop stolen
With that set-up I would go with a 21" pitch SS 3 blade. Stiletto is my favorite brand...Advantage II would be what you are looking for.
I had the same engine/drive combo, only the 190hp 2 bbl. version and had a 21" SS Vengeance that would push me to 53 mph and about 4600 rpm. The Stiletto will have more bite than the Vengeance, and should work well.
sethjon
Re: prop stolen
But the hole shot will suck and pulling a tube or skier will be difficult. 19 is much better.
