prop spec chart?
cliffblue
where can I look to find the diameter for alu prop # 48-32748-21?
bbfrs1
Re: prop spec chart?
You can always measure it yourself. If its a 3 blade, measure from center of hub to tip of blade, then multiply by 2. If its a 2 or 4 blade just measure across the blades. I ran into this same problem when I first changed my prop.
cliffblue
I'm looking at it on ebay. Seller hasn't replied to question. It will be a cheap spare if it is 13 3/4". Just got towed off the lake because of a spun hub. Not happening again!
