Prop slipping like the democratic poll numbers...
waterinthefuel
This is just a "This worked for me" thread, incase anybody else runs into this problem.<br /><br />My boat has a 150xp. It's a 1990 model. It wouldn't come out of the hole. It made tons of noise, threw water everywhere, but really, didn't do much. It's on a 18 foot F/S. Basically, it should blow this boat out of the hole. <br /><br />We dropped it to the bottom of the jackplate. Nothing. We rehubbed the prop to no avail. What did work was putting a ring behind the prob to stop the exhaust water from going around the outside of the prop, instead of through it. It is a Shooter 4 blade, and it had some minor dings on the outside edge of all blades, but more importantly there were holes drilled by the root of the blades. On this prop they were in the wrong place. We redid the prop, filled the holes, installed the ring and showered down on it. It literally leaps out of the water now. It shoves a huge wall of water backwards, and doesn't slip at all. <br /><br />If you are experiencing the same thing, check to ensure no gaps exist between the lower unit and prop. Also, plug up any holes drilled into the prop. They cause more problems than they solve.
walleyehed
Re: Prop slipping like the democratic poll numbers...
Disagree with filling the holes for every situation...they allow a larger pitch to be used and still have hole shot on most applications.<br />You say the holes on yours were incorrectly drilled....where were the holes in relation to the leading edge of the blade????
waterinthefuel
Oddly enough, drilled in front the blade. Meaning, when the air came out, it filled the cup of the blade with air. The prop shop guy couldn't believe it when he saw it. It was supposed to be drilled behind each blade, not in front! LOL
rolmops
I am glad to see that you found the problem and the democratic poll numbers must have shot up again.
K Hultgre
Does anyone have a link to post and a picture where to drill holes so I can reasearch this, sounds interesting.
Hooty
Witf?<br />Are you saying the holes were in front of the prop blades, towards the front of the boat?<br /><br />c/6<br />Hooty
walleyehed
I believe he means in front of the fwd portion of blade insted of where it should be....behind the fwd portion of blade in relation to rotation.
Dhadley
There are cases where we drill holes in front of the blade but it is not meant for acceleration. Its to cool the prop hub on some specific motors, mainly the early 3.0 liter Mercs. But we have seen holes drilled in the wrong place just because someone didnt understand where to drill.<br /><br />Good luck!
seahorse5
In the early SST prop days (1970's) for better acceleration on fast boats, we drilled 5/16-3/8" holes that were positioned 5/8" in from the from the front of the prop-gearcase intersection and 5/8" from the front root of each blade. This bled a small amount of exhaust to ventilate the blades to get rpm up quickly. As soon as the boat got on plane, the prop "hooked up" and there was no more ventilation. Some years later OMC came out with a service bulletin telling about how to do the drilling.
walleyehed
To add to this...if anybody gets any wild ideas......start small, as in, 1/8" hole to start with. 1/4" hole does ALOT more than you might think, and you MUST double-check to make sure your intended hole position does NOT go through the inner webbing of the hub........uh, yea, I did that once......
