prop size
smokingjoe600
I have a 87 26 ft sea ray with a mercury 350, I need a new prop. With 4 adults on board sometimes it is difficult or impossible to get on plane. Need some suggestions on what size, pitch and type of prop would work the best for me. Not to worried about top end just want to get on plane with no problem. Thanks
Teamster
To get an answer you should post what prop you running now, What gps speeds your getting, And what engine rpm your running.
steelespike
Good Morning and welcome. If you read the stickys at the top of the prop forum it will help you understand prop selection better.
We need your prop size(usually under the prop nut) and lightly loaded wot rpm and gps speed.
Would help to have the horse power and gear ratio sometimes on the outdrive.
