I have a 1990 Johnson 150 with low compression. I have recently purchased a 1989 Evinurde 150 and was putting my existing prop on that motor. There is a taper on the prop shaft where the thrust washer sits against on the 1990 but on the 1989 there is a second taper and it is preventing the thrust washer from going all the way up on the shaft (see pix below). As a result, I can't get the prop put on the 1989. It looks like the model number of the prop shaft is the same for both motors (according to the parts diagrams I've seen) so I'm guessing the 1989 has a gear case that's newer. I can see 333592 engraved on the side of the washer which is the correct part number for both motors so I'm at a loss right now. Any idea how I find the proper thrust washer to use or how to find out what the model
number is on the lower unit?
