Riverrat63
Thread starter- Joined
- Aug 2, 2003
- 9
I have a problem I would like to get some advice on my problem if possible?<br />Last weekend I had a rope get caught in my prop, and I think I got in some shallow water and may have hit something with my prop. Regardless how how it happened, here is my problem. <br /><br />After this occurred I was going back to the dock and when I would give my boat gas to go faster it seemed to slow down...then when I gave it less gas it seemed to hook up enough to let me go about no wake speed and get back.<br /><br />After I got the boat home and pulled the prop off and removed the rope, I shift into forward and at the prop shaft I can turn the prop. With the prop OFF I can turn the shaft as well and I get a "clicking" sound about every 1/4 turn. When in reverse, the prop shaft doesn't turn (with the prop on or off) as would be expected due to the engine compression causing the resistance.<br />Everything seems normal in neutral because I can turn the prop and shaft forward or reverse with no resistance. <br />I have seen in other forums, that it's possible it would be a problem at the prop hub level, but since the prop shaft is able to spin in forward gear I would assume that I need to look at something on another level. Any input would be appreciated!
