Re: Prop shaft replacement on 1999 Merc 25 h.p.
A complete lower unit seal kit,new lube (natch).<br />Other than that,it's all up to luck (that no other parts are worn-out of spec or broken.<br />This is not likely, if it doesn't have much run-time with a bent shaft.
