Prop shaft removal on older 5hp sears outboard??
zig
Hello,
I had problems removing the old prop. So in doing so I accidentally broke the end of the shaft with the threads on it. So now I have the whole bottom section disassembled. Below are pictures of what I have:
Does anyone know how I remove the shaft that the prop was on?? It looks like it is maybe held in with a dowel inside the shaft with the gear on it. I need to find something small enough to pop it out I guess.
Any help is appreciated...
zig
Re: Prop shaft removal on older 5hp sears outboard??
I knocked out the pin and it came right out....
