Prop shaft oil seal - Johnson 50hp 2000 model
woodynt
Hi,<br /><br />I recently noticed a very slow oil leak coming out from the prop housing. (Johnson 2 stroke 2 cylinder 50hp 2000 model) The oil is very clean in color so I assume it is from the gearbox. I checked the gearbox oil. The level was a little low but clean not at all milky.<br /><br />I bought a new prop shaft oil seal with the intention of installing it (I am in a remote area so I have no choice but to do repairs myself)<br /><br />I took the prop off and got down to where I can see the top of the oil seal. But it is not obvious what to do next.<br /><br />I'm not even sure the seal needs replacing. Did it only start leaking when I was flushing the engine after the last run? If not how come the oil is not milky? Can the seal leak oil out without letting water in?<br /><br />Do I need to replace the oil seal? If I do, how is the best way to do it?<br /><br />any help would be greatly appreciated
wilde1j
Re: Prop shaft oil seal - Johnson 50hp 2000 model
You need to get an OEM shop manual and parts list 1st. Most OMC LU's have two prop shaft seals (installed back to back) and you need to pull the bearing carrier 1st to install. This requires a spec tool (homemade or purchased).<br /><br />I wouldn't begin w/o the PL and shop manual, however.
Dhadley
It is possible to change the seals without removing the housing but it requires a special puller set. So now you get to choose which special tool to buy. <br /><br />Good luck!
Dhadley
almost retired again
Hi Woodynt,<br />The first thing that I would do is to drain the gear lube. Then pressure test it, if it holds pressure then you probly arn't leaking oil. Most all of the seals that OMC put in the lower units were a back to back set. One held the oil in, and the other kept the water out.<br />Good Luck
woodynt
thanks everyone, I will try the pressure test first and go from there.
