Prop shaft oil leak
bigbill64
How big a job is it to replace the seals on the prop shaft of a 1991 40 hp Mercury. Is this something I can do myself? Thank you.
carholme
Re: Prop shaft oil leak
It is not that big of a job but you will need a pulller and a tool to remove the cover nut. Are you sure it is the prop seals leaking. Where is the leak?
Do you have the service manual and if not, what is your engine s/n?
Gerry
bigbill64
Gerry
Hi Gerry: Serial # OD129595. There is a small lak where the prop meets the lower unit and it drips down the skeg. I presume it is the seals on the shaft. Yes, I do have Clymers manual. Thanks, Bill
carholme
Bill;
Your s/n comes up as:
MERCURY - ( 40 H.P. (1992 ))
Serial No: 0D129595 Model No: 1040412MD
Parts and Service Bulletin list for s/n 0D129595:
Search Results - Crowley Marine
The Mercury service manual for your engine is 90-814676. See my message to you in Notifications at the top of this page.
Gerry
