wilkin250r
Thread starter- Joined
- Feb 9, 2003
- 570
I had an old 1989 Force 125 with a seized piston, so I replaced it with a 1988 Force 125 off ebay.<br /><br />The problem is, it seems there was a change in the prop shaft nut size during these years. My old 1989 shaft nut is too big, and the new 1988 didn't come with a shaft nut. I've tried looking through the manual for what I need, but I can't decifer all the part numbers.<br /><br />What prop shaft nut do I need for a 1988 Force 125?<br /><br />My new motor apparently has a problem with the ignition. I only get spark on the #3 cylinder. I haven't deduced whether it is the trigger or the CDI unit that is causing the problem. Both the 1988 and the 1989 have the blue CDI units, does this mean they are interchangable? I have no reason to suspect that the ignition is bad on the 1989 unit.
