Saltrunner
Thread starter- Joined
- Sep 14, 2010
- 2
I need a little help selecting the best prop for my situation. The Motor Power head is a 175HP Mariner and Carbs. The Foot came from my older Motor Mercury 150XR2. The Prop is a 22 pitch SSteel 3 blade. Its on a light weight 17.5 ft Glass stream bass boat. The RPM will reach around 6700 RPM Maybe 7000 at times. I'm not an expert on what RPM I should be turning but I feel I should be ok going to a higher Pitch Prop. My goal is to not blow the engine and at the same time get all I can from the engine far as top end. With the 3 blade 22 pitch that's on it now it will plane out in a second or two if I gun it. I also would like to know what difference I may experience If I put a 4 blade prop around 24 pitch. Do you think a 4 blade higher pitch may speed the boat up or slow it down? And would I expect a Rpm drop. What would be a safe RPM for this setup to not danger the engine? The engine is an outboard with the oil injection removed. The boat and original 150 Motor was 1988. Maybe I didnt leave out to many details if so ask me and I will reply.
Thanks,
S.R.
Thanks,
S.R.
