Prop RPM question:
LOW MN
If the Mercruiser 165 HP is at 4,000 RPM, what would the Prop RPM be?
1980Coronado
Re: Prop RPM question:
You'll need to find out what the out-drive gear ratio is. Divide the engine rpm by the gear ratio and you'll have the prop rpm.
Texasmark
Following along with the thread, curious as to why you want to know the prop rpms? Just a question.
Mark
Dhadley
He's probably wants to calculate slip %.
Robbabob
Knowing the gear ratio, engine operating RPM at WOT, actual speed, boat weight, (and I think engine HP), properly input into the right prop calculator will give you slip %. I haven't heard of a tach to measure actual prop rpm while at speed, so I am curious about the benefit of knowing.
1980Coronado
You need to know the gear ratio to input into the slip calculator. Engine RPM divided by gear ratio x prop pitch (inches) x 60 min/hr divided by 12"/ft divided by 5280 ft/mile will give you theoretical miles per hour. Compare those numbers to the actual measured speed and you can figure slip.
