Prop replacement on a 48HP Johnson
jamsoccer12
Hi everyone,
I have a 1987 20ft JC Suntoon pontoon boat that has a '94 48hp Johnson outboard on it. I need to replace the prop on it...but there are no markings on the current prop (I thought all of these were stamped!). Anyway, does anyone have any suggestions on what size prop I need to look into? Thanks in advance for all of your help- I really appreciate it!
jestor68
Re: Prop replacement on a 48HP Johnson
The folks over in the pontoon forum might have some ideas.
steelespike
Have you looked under the prop nut?
There is a Michigan 10" 4 blade listed here at boats that should be a close fit.
Just look top Evinrude 48 1994.
Would be best to see if there is a number under the prop nut.
