Prop question
wcso549
I recently posted that I was having issues with my 88 Johnson going in forward and reverse, I figured out the problem... My props insides were all gone. My question is is a 12.75 x 21 prop a good prop for an 18 ft pontoon boat? Its on an 1990 Johnson 88 HP. Thanks for you help.
steelespike
Re: Prop question
Thats way wrong.If I had to guess on a 18 foot pontoon I would start with a 13" pitch.
If there is a choice on diameter get the larger diameter.The Solas props have a good reputation.
wcso549
Re: Prop question
Thanks for the info, could you tell me the difference between the props, why one is better than the other?
I'm really new at this so learning everything i can. Thanks.
jestor68
Re: Prop question
All brands of aluminum props are going perform OK on a pontoon boat. Usually, Solas is less expensive.
I recommend a 15 pitch, based on the info that your ratio is 2.42.
With a rpm range of 4500-5500, you'll want it to turn at least 5000 rpm to develop full power.
