Prop Question
pauleqer
I have a 99 Stingray 190RS 4.3 merc alpha 1.81. The props i have now are:
14" 23p stock merc aluminum. 4800rpm about 54mph-a little dinged up
14" 23p Mich Wheel Vortex aluminum. 4800-5000rpm about 54-55mph-good light load cruising, not so great for watersports
14" 23p 4 blabe QL aluminum. light load=4200rpm 48mph. loaded=4100rpm 45mph-good light load hole shot not so loaded with tuber
14.25" 19p 4 blade QL aluminum. light load=5000+rpm 46mph. loaded=4800rpm 44mph-good hole shot not so with speed....
Im looking to get a SS prop because of some nasty weeds and Mich wheel SS are on sale here at iboats :D What would be recomended? Want something for an "all around" prop, probably comparable to the stock 23" 3 blade. Ill put the 19" on for watersports...0608122309.jpg This was the new 19" 4 balde before a couple hrs of running through weeds.....
90stingray
Re: Prop Question
Sounds like that Michigan Wheel is getting it done for you! 55mph... thats awesome. Well, your numbers are close to mine, so i will share. I had a stock 23p 3 blade alum on my glastron that went 52mph. I went with a 14.75 x 21p solas 3 blade ss that runs me right at 50 and 4650rpm's. I would like a little more speed... but i think it's a good all around prop.
http://boatpropellers.iboats.com/Me...-148-21_Propeller/765/9584/?*******=855977844
pauleqer
Re: Prop Question
It was a bit sketchy goin 55 with the engine screaming at 5000rpm and trimmed all the way up, but its fun :D But its annoying when theres big spots of paint missing off the blades... makes the boat look like crap IMO. Im thinking either a 23p 3 blade or 22p 4 blade but I have no experience with SS. The 4 blades are awsome around the dock.
Philster
Re: Prop Question
Then get the 4 blade @ 22p in stainless steel! That's the right conversion. Plus: SHINY! :)
pauleqer
Re: Prop Question
You think it would turn enough RPMs? the 23p 4 blade I got only gets up to 4200 maxed out and trimmed up..
90stingray
Re: Prop Question
I don't think it will. Look at the props in my earlier post. ^^^^ Get a SS 21p 3 blade... and i bet you will have rpm to spare but be within range.
