Re: Prop question
walleyehed,<br /><br />Our trim tab systems are much tougher than you think. The systems have to be to handle the forces they deal with day in & out in normal operation, so snagging a stump or some timber while you are working the bank won't be an issue. When they are installed correctly and fully retracted, the trim planes will be angled above the hull's running surface. This way you are able to run as if you didn't have trim tabs installed, since there will be times that call for this. With our system you can adjust each trim plane individually, on the fly using the trim tab control, to meet the changing sea & load conditions as you run from each fishing hole. This allows you to dial in just what you need when you need it! Also, many bass boaters are using our Auto Tab Retractor (AR512) to retract their trim tabs during their hole shot, since they are running jackplates along with the tilt/trim to maximize their hole shots and to make sure they reach the fishing hole first! <br /><br />If you have any more questions, please feel free to contact me.<br /><br />Sincerely,<br />MJ Thomas<br />Bennett Marine, Inc.<br />Client Services<br />trimtabs@earthlink.net<br />
www.bennetttrimtabs.com
