Prop Question.
Gary H NC
I'm running a 3 blade old stainless thats nicked up and has rough edges.<br />I can't read the serial number but it is a 20 pitch x14.5<br />I'm getting 4200 rpms at WOT and about 41 mph.<br />I'm wondering if going with a new 19x14.25.<br />Will i loose alot of top end.I was wanting to get the rpms up a little.Hole shot is not bad with the 20 pitch.<br />19ft 4.3
Gary H NC
Re: Prop Question.
Thanks LubeDude.How much top end should i figure giving up?
Silvertip
Honorary Supreme Mariner
Re: Prop Question.
I assume we are talking outboard here and not I/O? Before spending a bunch of coin on props, play with engine height first. If the AV plate is even or below the bottom of the boat, raise the engine mounting. Re-test. Raise again, re-test. The theory is less engine in the water, less resistance, higher RPM. Just don't go so high that you lose water pressure. A water pressure gauge is a valuable and inexpensive addition to the console as it also indicates relative condition of the water pump impeller. When you reach optimum setup, then determine the prop you need.
Silvertip
Re: Prop Question.
Gary H NC
Re: Prop Question.
Its an I/O..4.3 Cobra..<br />I'm not wanting to loose speed but get the rpms up a bit..gaining speed would be nice.<br />Hole shot is fair now.<br />I just think its time to replace...prop looking kind of rough.<br />See if i can find some more numbers or markings on the old prop.
Ron G
Re: Prop Question.
I dont know what the recomended rpms for that motor is but it seems a 19 would work,it should put you around 4400.but my a loose a few mphs,if the prop you have now puts you close to your rpm range you could get it reworked.
