prop question help.
LUISJGC
hello.<br />i have a brand new satinless steel prop for a 30 hp nissan 2005 ., my question is can the hub be changed to use it in a 1991 30 hp evinrude .<br />or im stuck .?<br /><br />thanks!!!<br /><br />luis
walleyehed
Re: prop question help.
Not everyone is using 100% of their time setting in front of the 'ole PC waiting to answer questions...sometimes it may take a day or so, and weekends are bad for obvious reasons, as the Guru's are often fine-tuning their own rigs...<br />Depending on the hub bore diameter, there "May" be a prop-shop good enough to make it work....good chance it will require a different thrust washer just due to the hub design.
