Prop Question 125 Force
rammerjammer05
87' 125hp Force outboard. Serial#1258V7B. Running a 19pitch aluminum prop on a 16 1/2' VIP Bass Boat. Looking to upgrade to a stainless steal prop. I'v been searching for about 3 weeks now but can't seem to locate one. My motor is a single exhust and all the steal props I found are for a dual-exhust. Will a dual-exhust prop work and if not came someone point me in the right direction. ]
Frank Acampora
Re: Prop Question 125 Force
Dual exhaust props will work and there is no loss of performance. Michigan makes a line of stainless that will fit. You can also with some small modifications use a Ballistic ,Vortex, and others.
First photo is the Ballistic by Michigan, second the collar to replace the thrust washer. Fourth with red tailcone is the Michigan brand prop and fifth is an old Michigan bronze racing two blade off a Mercury. See: there are lots of options. Search my earlier post on modifications needed to install the Ballistic and if you want, search my post in the prop forum an performance of it on a 105. (The one in the avatar)
