An F115 2006 Yamaha the propeller isnt spinning like it should there is no power when engine is running and it is in gear...
Not sure what else other than a gear issue it could be....Any help is always greatly appreciated thanks.
the prop could be "spun", put it in gear (with the engine off) and see if you can spin it, or take it to a prop shop and ask them to check it out. that is the easiest and cheapest possible problem you could have.
Thank you for the quick reply. I will check that tomorrow and post it. How about the shift position switch I was reading do you think that it should be worth checking if the prop checks fine?
