Prop Pitch for 70EL77s for Glastron V156
John Rude
Well, it's been one of those days where I should have just stayed in bed. Took advatage of some nice weather and buggered my prop beyond reasonable repair on a bed of rocks. :eek: It is a 13 tooth, but cant find pitch stamped anywhere- or where it should be. Also, who has the best deals? Don't need ss or anything fancy.
Thanks in advance for any direction.
JohnRude
Big Bubba
Re: Prop Pitch for 70EL77s for Glastron V156
John Rude,
Where you located at? I have a 12 3/4 X 17 pitch 13 tooth prop that came off a 1983, 70 horsepower Johnson outboard I would like to get rid of that is in good shape that came with the motor that I used for my Pontoon Boat but it want work since I needed a higher pitched prop. Let me know. Take care Bob
ezeke
That motor shipped new with a 11-3/4 X 17, 3 blade aluminum propeller #386841. That is superseded by propeller #763462.
You may find the part number stamped on the hub when you remove the propeller and lift the thrust bushing. .
John Rude
John Rude
