diamondlangus
Thread starter- Joined
- May 26, 2009
- 35
1) Performance issue you are trying to correct. Low RPM at WOT, it is currently running about 4400-4500 rpm
2) Current prop manufacturer, model, aluminum or stainless as a minimum. Solas rubex aluminum
3) Current prop diameter and pitch (required). 11" 15 pitch
4) Wide open throttle RPM and speed with an average load (very helpful) 4400-4500 rpm
5) Engine/drive make, model, year, and HP 1993 ish Force 70hp
6) Boat make model, year, length and weight 1995 spectrum 16' sport, boat weight with gear and me about 1450lbs
Don't know if it matters I live in WY and run at about 5200'. compression ranges from 100 to 108lbs. I am trying to decide if I should drop to a 13 or 14 pitch prop to get the RPM up. the boat is running 30 - 31 mph according to GPS. If I drop the pitch size but my RPM goes up will I maintain about the same speed or will it change much?
The Throttle is opening up all the way so I know that is working correctly. I am also going to put new spark plugs in they look a little old. This boat is new to me so I don't know how old they are.
