Re: Prop Noise
Thanks to this topic, I finally started collecting a few previously posted explanations. This is the first. I copied and pasted this and made a few minor revisions...
Clutch Rattle Explained
Your powerhead doesn't run smooth at all, especially at idle. The crankshaft is constantly slowing down with compression and speeding-up with combustion. A 2-stroke 3-cylinder slows and speeds 3 times each revolution. If you graphed crankshaft rotation velocity, you would have something closer to a sine wave than a straight power line.
What's happening down in the gearcase is that the mass of the propeller keeps it turning constantly...the old object in motion tends to stay in motion thing. Graphed-out, it would be a straight line. So every time the crankshaft slows down, the mating surfaces of the cogs of the sliding shifter (clutch dog) and gear form a tiny gap as the prop continues it's constant spin. When the sparkplug fires and speeds-up the crankshaft, the cogs slam together. That's the noise you hear. At idle, those speed-slow cycles are much more pronounced than at higher RPMs.
It sounds awful, but it's not generally destructive since the power at idle is so low. It is much more noticable with stainless props than aluminums because the added weight (mass) keeps the stainless prop spinning smoother when the gap forms and then resists speed-up when the cogs slam together again.
I wouldn't advise trying this at home, but imagine pushing a car with an SUV. Slow down the SUV and you get a gap between the vehicles. Accelerate to resume pushing and there's a bump. Now imagine that the pushed vehicle is a big truck. The bump is more like a jolt.
I haven't heard the clutch rattle complaint with makes other than Mercury, but I work mostly on Mercurys. As a marine mechanic, it seems that Mercury products in partcular give me a certain degree of job security.
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
