Prop MD
Flhx
Beware of propmd.com. Bought a prop from them that they suggested would be the best for my set up. Turns out my engine overrevs now and performance is down. They will not accept return because it has been used on the engine. Just thought I would give a heads up.
Don S
Re: Prop MD
Any prop is only an educated guess as to how it will work. The only way to find out if it will work for sure is to test run it. Was this return as part of their exchange program? or refund?
Here is their return policy.
http://www.propmd.com/t-returns.aspx
Tail_Gunner
Re: Prop MD
Even with very detaied information that is accurate it can be very difficult to get it right, i cannot tell you how many times the posted information is incorrect and how much work it seems to get it right without spending needless money. But you can explain you issue and see why that happened or get some insight
va804
Re: Prop MD
This was a great experience using Prop MD. Send it off to them in bad shape. What I hot in return was a prop which looked better that new. The responded to my emails with questions I has in a very timely manner. They also have the best prices out there. I had no problems with them. prices were exactly as advertized on line.
SkiDad
Re: Prop MD
you can probably get 80% of your money back on ebay - especially this time of year
Re: Prop MD
Ayuh,.... 2, 1/2 Year old thread fellas,....
