Hi,
In order to have a spare prop I purchased on ebay this one: 48-13702-21, Quicksilver Mirage. My outdrive is Alpha One (Gen 2, I believe). The diameter, pitch and the number of splines are OK. But, when I tried to put it on, I found that the prop is shorter than needed!
When the prop is pushed all the way in, there is still about an inch or so of the splined shaft sticking out, and I cant tighten the nut. Is it a wrong prop? There is a metal hub in it (not the flow torque hub like on my other prop) not sure it can be replaced easily. The thrust washer is there.
Am I still missing another part, line a very thick washer or something, to place just before the nut? Any advice is very much appreciated.
Thank you.
Thank you.
