Prop ID
kevdp4
I have been running this prop for 14 years on my boat. I have been very happy with the performance of the prop but I have spun the hub twice now. It is a four blade polished stainless that has no scratches or dings. I cannot tell the pitch of the prop, I assume I can measure the diameter.
The only number is F7RM31194002 on the hub rim.
Can anyone tell from this number what I have? (Pitch and diameter)
I would like to have a new hub pressed in but I don't trust the reliability so i probably will get a new prop. Would like to get the same setup.
steelespike
Re: Prop ID
Disregarding the number it would help to know The motor brand and size,Boat brand and size
Diameter of the prop. typical load. wot rpm and gps speed.
Have you looked under the prop nut for the size?
kevdp4
Re: Prop ID
The motor is 1992 Mercruiser 350 Alpha 1, Gen 2
1992 Celebrity BR 200
Diameter: 13.75"
Typical load: 4 people full tank of gas, general cruising, wake boarding, tubing.
WOT is around 4500-4600
Never checked GPS speed, Speedometer speed around 47, 50 on a good day. (Checked against other boats)
The prop is off the boat, there are no other numbers or identifying marks.
