I have a Ballistic 17" (13? x 17) ss prop, the prop has never been on ground, and has no visible defects - a fantastic prop by the way.
But the hub is moving inward into the prop, the rubber bearing does not look damaged, and it is not loose in any way.
Over the last year it has moved app ?", and I cannot fit it without additional washers.
Should I continue to add washers or...
They are too expensive to throw out
The boat is a Campion 485, with a Tohatsu 90HP TLDI.
Thanks
Casper
Thanks
Casper
