Prop Help
Bennettc
I tried asking for help in the prop section, but didn't get a response. I am looking to replace my current prop as it is pretty beat up and I would like to use it as a spare. It also seems like I need to lower my RPM's. I am mainly concerned with performance with a full load (4-6 adults). I would be open to an big eared or 4 blade prop if it would help.
Please let me know what you guys think would be a good prop to move to.
Thanks!
Here is my info:
1) Performance issue you are trying to correct. Less strain on motor and more speed with full load.
2) Current prop manufacturer, model, aluminum or stainless as a minimum. Michigan aluminum-386909
3) Current prop diameter and pitch (required). 12.5 x 13
4) Wide open throttle RPM and speed with an average load (very helpful) 6100-6300. 14mph
5) Engine/drive make, model, year, and HP johnson 40hp 1990
6) Boat make model, year, length and weight Tracker Bass Buggy 18ft
EGlideRider
Re: Prop Help
Depending how 'beatup' your current prop is, that could easily be the reason for the high R's.
I would try a 13X13 or 13X14.
crb478
Re: Prop Help
I am a fan of the 4 bladed props on pontoons. For your set up I would consider a 15 pitch prop, that should get you in the 5500 rpm range where you want to be and pick up a little speed as well.
papasage
Re: Prop Help
my pontoon has a 4 blade 11 pitch 12 mph. tried a 16 pitch 3 blade ss and it would hardley moove the 24 ft pontoon probabley at a good walking pace .
Bennettc
Re: Prop Help
Thanks for some of the input. My current prop has a couple small chunks taken out of one of the blades and my be slightly bent. When I do some of the prop selections I don't get any results for a 13x14.
I may go with a new 12.5x13 and see how it does.
Does anybody know what the target RPMS would be for my motor? The model number is TJ40ELESR.
EGlideRider
Re: Prop Help
I don't think that prop is beat up enough to cause the high RPM's. I still recommend the 13.
