psteurer
Thread starter- Joined
- Nov 10, 2008
- 366
Hello,
I am running a 1989 20hp Johnson with the standard OMC aluminum 10 x 13 prop that likely came with the motor. My WOT with a fairly light load is 4600 rpm and speed is 21 mph according to a GPS. According to my OMC manual the motor is rated to run WOT between 4500-5500 rpm. The motor is on a 1963 14 foot aluminum Sea King runabout boat that weighs about 275 pounds.
I would like to get my rpm's higher. I have been looking at 10.5x12, 10.5x11, and 11x9 prop likely in aluminum. I could also go to stainless steel. I am thinking that the 10.5x11 would get me in the low 5000 rpm range and would be good. What would be a good prop diameter, pitch, and material should I go with?
