bigbasser54
Thread starter- Joined
- May 21, 2008
- 16
I am upgrading from a Black Diamond prop 23P to a Turbo SS 24P Prop. The Black Diamond required a Flow Torq II Hub Kit, the Turbo has a built-in Hub. My question is that will any additional hardware be required to install the Turbo Prop (ie. Thrust Washer, nut, tab washer, drive adapter), or can I use the needed parts mainly the thrust washer, tab washer, and nut from the flow torq II kit. My setup is a 97 Force 120 on a Nitro 700 LX. Thanks
