Prop go into gear does not move?
Status
Not open for further replies.
bigsharksmallpond
I have a 5.8 corba I had it on the lake and half way across it stop working. when I got home check to see if I could put in to gear all gear work motor revs what could be the promble? Could it be my shifting cable if so tell me how to check it. Thanks;) If it is the coupler how do I check for it? If you need more info what do you need. Thanks again
gcboat
Re: Prop go into gear does not move?
Really need a tad bit more info. If the motor works and you have no power to the prop might just check your coupler. My $.02
Brewman61
Ensign
You resurected a 3 year old thread. The original poster has only made one post- this one, so unless you know the poster you'll likely never get the answer to what.
Status
