Re: Prop for a 1992 190 Horzion 5.0L
Hey chuck, I have a 93 horizon, I went to a pirahnna polymer prop. 15X19 pitch. What a difference in performance... and the fact that if damaged each blade on the prop can be individually change out for about 19 dollars. The inirial cost is about a hundred bucks. However well worth the money since all you change out are the blades if they get to busted. I hit a log once and it took a good chunk of the blade and did not effect performance what so ever. Called the company 3-days later new blade installed no problem. Say good by to prop blending shops forever with a pirahnna prop!!!
