Prop for '97 Mercury Tracker 75hp motor?
otter300
I am looking to replace the prop on my 75hp Tracker motor, where do I find the info as to which is the correct pitch prop that I need? Any help would be appreciated.
steelespike
Re: Prop for '97 Mercury Tracker 75hp motor?
Your prop numbers should be under the prop nut. Written; diameter X pitch.
Pitch is the key number. If you give us your boat description and present wot rpm and speed We can help you determine if you need a prop change.
It may be cost effective too have your prop repaired at a prop shop.
