Prop for 75hp Johnson
Johnmari
Would like to know best prop for 75hp Johnson on a 18' bass buggy pontoon boat. I know it is a short case and 13 spline I would just like to know prop size and pitch and 3 or 4 blade for best performance. Thanks in advance for your help.
Johnmari
Yes it has the short gear case on the lower end
flyingscott
You should have put this in prop questions. Props are not a 1 size fits all thing. You need to find a prop that will let your motor rev to 5800 rpm with a light load. Michigan wheel has a prop finder on their website. Or you can call a dealer and ask what Johnson would recommend for a prop it may take some experimenting. Does the motor have a prop already?
Honorary Supreme Mariner
If this is the 15" transom , short shaft / small gearcase than it may not be suitable for an 18' boat.-----------Meant for small 13 / 14' boats and light loads.
